I am a fairly new NCRS member joining about 2 years ago when I wanted to learn as much as I could about mid-year Corvettes. I have been wanting another one since I sold my NOM '64 roadster back in 1979. I always told myself that if I ever got another mid-year, it would have to be a matching number car.
After about a 5 year search I finally purchased a one owner 1967 Coupe. It took me about 3 years to close the deal. I took somewhat of a chance since the car has been parked since 1974 and has not been started since 1974. The car was garage kept and is in good shape and has some nice options. L79, TI, M21,3.70 Posi, A/C, P/W, Headrests, Tinted Glass, Offroad Exhaust, AM/FM. Color is Lynndale Blue with standard black interior.
Included with the car was a good amount of documentation including the P-O-P, dealer copy of the build manifest (similar to window sticker or tank sticker) and full maintenance history with receipts.
So far everything I have checked is original with proper date codes with the exception of the fan which is a 7 blade (date coded 72) and a big block fan clutch. For some reason the fan and pulleys were removed from the engine and were in a box of parts. The previous owner claimed they were the original.
Now to my question. I purchased a "replacement Water Pump" to be used temporarily to get the engine running. It was purchased from a major Corvette supplier. My plans are to have the original pump rebuilt in the future. When test fitting the double groove pulley to the new pump I noticed the pulley hit the pump casting ever so slightly in one place just on the inside near the outer diameter. The pulley fits fine on the original pump. Can someone confirm that I have the correct water pump pulley? The aftermarket pump casting is slightly different than the original. I could grind a bit off the housing for clearance.
Here's a list of what pulleys I have:Water Pump, 2 groove #3848904, 5.825"OD, Crank Pulley 2 groove #3858533 6.750" OD, Alternator 3.025" OD, A/C 5.662" OD. All seem to be deep groove. I would also like to know the belt lengths. It is very confusing trying to figure this out with the combination of options. The A/C compressor pulley seems larger than normal also. Maybe because of the 3.70 rear gears?
I made about C1 Engine accessory pulley alignment. It discusses water pump pulleys and hubs with some data that may help. Much applies to the C2 engines, with the exception of the Generator versus Alternator, and the infamous Harmonic Balancer Spacer which the Ci engines require due to their "different" front engine mount arrangement. Kudos to fellow member Dave Zuberer for his conversion editing and PDF magic.
