1970 Quadrajet: Proper hole for attaching throttle cable? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4542
    1970 LS5 Q-Jet 7040205: Which hole in the carb's linkage should the throttle cable attach?
    I copied the photo below from the internet showing the three holes to choose from. (Not my car. Yes, the forward mounted spring in the upper hole should not be there.)
    Are multiple holes provided to tune the sensitivity and position of the throttle with the gas pedal? Or should only one of these be used?
    Thanks.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • 6942
    Re: 1970 Quadrajet: Proper hole for attaching throttle cable?
    Mark, the position on carb. arm should make a straight line from cable bracket to arm.
    • Mark E.
      • April 1, 1993
      • 4542
      So use whichever hole best achieves this?
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
        • 6942
        Mark, yes, throttle arm should be at rest so idle speed is normal and you don't want any binding of linkage when full throttle is achieved.
        • Mark E.
          • April 1, 1993
          • 4542
          I appreciate what you're saying Edward. But for a specific application (for example '70 Corvette LS5, Chevelle LS5, full size Chevy, ...) I'm surprised that amount of adjustment would be needed to compensate for production variation. Does throttle cable height vary much in production?
          Is it possible the carb's linkage is drilled for use in various applications, and each application uses a specific hole?
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
            • 15599
            Dumb question here, but does the AIM show you which hole to use?
              • 3416
              Hi,
              Yes the AIM does show which hole is intended for the linkage stud.
              There's even a detail to show it.
              It's important to get the stud in the correct hole so there's room for the always popular additional return spring to run from linkage to the front engine lift bracket.
              UPC6, Sheet D2, View A.
                • 6942
                Mark, the different car lines will have different cables and there is a overall difference in height of intake manifolds and carburetor linkage and can change the arm height, the cables do have some flexibility.
                • Mark E.
                  • April 1, 1993
                  • 4542
                  Not really. The only reference I found was UPC 6-D2, View B. It shows two holes (not 3) in the linkage, with the stud using the lower hole. It doesn't look much like the real part, hence the question. Nothing in the LS5 section.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Edward B.
                    • March 29, 2013
                    • 691
                    If the 1969 L36 is configured the same as the 1970 LS5 (which I believe it is), the picture you posted has it in the correct hole. Here's mine...
                    Ed
                    • Gary B.
                      • July 31, 1979
                      • 926
                      This might help...
                      Gary
                      • Mark E.
                        • April 1, 1993
                        • 4542
                        Originally posted by Edward Bertrand (58273)
                        If the 1969 L36 is configured the same as the 1970 LS5 (which I believe it is), the picture you posted has it in the correct hole. Here's mine...Ed
                        Thanks Ed. This is a good example of ambiguity created by the handmade drawings used in the AIM. I wonder why photos weren't used instead? I think they had cameras in the 1960s.
                        You probably know this, but the protective sleeve that goes around the throttle cable is broken/missing on your car.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Edward B.
                          • March 29, 2013
                          • 691
                          Yeah, I'm not sure why either. Still works okay, but looks kind of funky.
                          Ed
                          • Mark E.
                            • April 1, 1993
                            • 4542
                            Originally posted by Gary Bosselman (2575)
                            This might help...Gary
                            Thanks Gary. Edward's and your replies are appreciated since the cable on my car is attached to the upper, rear most hole. This is telling me I should change that.
                            Nice, original looking motor! Shouldn't the vacuum line from TCS to the VAC be routed under the fuel line, not over it as shown? That's what AIM shows.
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
