c2 BW trans ID - NCRS Discussion Boards
c2 BW trans ID
  • John G.
    • January 1, 2006
    • 85
    c2 BW trans ID
    My friend recently obtained a bw t10 dated 6-19-63 side plate it has wk3132 stamped on main case. Was told it was from corvette. He doesn't want to use it in another project if it belongs in a corvette
    Thanks John G
  • Harry S.
    • July 31, 2002
    • 5346
    Re: c2 BW trans ID
    John, A T10 with that date on it is after GM started using Monsey transmissions. If it was a Corvette Transmission next to the WK3132 would be the VIN derivative number from the Corvette it was installed in originally.
    • Loren L.
      • April 30, 1976
      • 4104
      Re: c2 BW trans ID
      Harry's right, it's a T-10 built for service and assembled Oct 31, 1963 by the second shift.
      • Timothy B.
        • April 30, 1983
        • 5202
        Re: c2 BW trans ID
        I agree that it's a service transmission or from another vehicle still using the T-10. Keep in mind if it's a service transmission for a Corvette the internal parts could have some value depending on the condition.
        • John G.
          • January 1, 2006
          • 85
          Re: c2 BW trans ID
          Thanks to all that responded. After seeing the tranny, for sure wasn't in a '63 or a corvette. . had a steel case and no vin #
          John G
            • 43286
            Re: c2 BW trans ID
            John G
            John------
            If it has a cast iron main case, then it's a 1957-61 T-10. It's even possible that it's not even a transmission for a GM application. T-10's were also used for other auto manufacturers.
            • Eric D.
              • February 1, 1992
              • 42
              Re: c2 BW trans ID
              Buick used iron case T-10's thru the 1965 model year...
              Hope this helps... Eric
