71 Front Sway Bar: Paint or Natural? - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    I am redoing the front end and had the front sway bar powder blasted and cleaned up. The question now is should I leave it natural and use RPM on it OR spray paint it with krylon industrial semi-flat black?
    Which color is more correct? I heard a new NCRS Technical Info & Judging guide maybe coming out--I know the 2006 (4th edition) states it can be either.
    Which finish would be easier to maintain so it looks good semi-flat black or natural finish--assuming both are acceptable.
    Thank you for all your help and advice!!
    • 11698
    Re: 71 Front Sway Bar: Paint or Natural?
    It's still going to be listed as either.
    If you don't know what yours was, I usually say it's easier to paint it and have it protected than continuously try to keep it natural, or get points off for cast blast.
    • Mark E.
      • April 1, 1993
      • 4609
      I like Patrick's advice.
      I went through the same inquiry while restoring my '70's front suspension, and decided it was my choice. I thought a natural sway bar would give this area of the chassis a more detailed look (vs. most everything some shade of black). I don't like rust and had no intention of judging the car, so I used POR15's cast color. Very durable and looks natural to all but the discerning Flight Judge.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Paul C.
        • November 12, 2007
        • 511
        I really like the natural appearance but I worry whether the rpm will keep it from rusting. I don't mind retreating as long as it doesn't need a tx every 2 months.
        • Paul O.
          • August 31, 1990
          • 1716
          Paul
          The vast majority of original anti roll bars on original 1970-72 cars are painted a finish that look like the A-arm finish and gloss. For me black is typical un- painted is unusual.
            • 15640
            After it has been blasted it will be a hard climb to make it look natural. There is nothing natural about blasting unless you have a half-shaft for a LT1, BB or M40. Your easiest course of action at this point is to find the worst looking black goop that passes for paint and slop it on.
            • Tracy C.
              • July 31, 2003
              • 2739
              .... Your easiest course of action at this point is to find the worst looking black goop that passes for paint and slop it on.
              Spoken like a man who understands what truly restoring a Corvette to "factory fresh" condition is all about.
              Thank you for that Terry,
              tc
