What numbers on the fan & water pump Pulleys? - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    What are the correct numbers on the 71 LT-1 fan and water pump pulleys? 3991425 for water pump? Fan pulley?
    • 43273
    Re: What numbers on the fan & water pump Pulleys?
    Paul------
    The 2 groove waterpump pulley should be GM #3991423. The 1 groove pulley (AIR pump driver) should be GM #3991425.
    • Paul C.
      • November 12, 2007
      • 511
      The single fan pulley is 3991425BX.
      The 2 groove water pump pulley is 3991423BW
      I guess everything is correct.
      THANK YOU.
