58 jack handle markings - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I'm looking for a jack handle for my 58. I need to know if they are any type of marking stamped on it to identify it from a passenger car or truck.
  • Nicholas L.
    • November 1, 1982
    • 342
    Re: 58 jack handle markings
    Check the judging manual if you have one. The dimensions of each section are critical and whether or not the bends are at right angles.
    • David B.
      • March 1, 1980
      • 689
      Interesting question since handle assembly 3706351 does not show up in any 55 thru 58 parts book. To answer your question, the blueprint states it is 44.50 inches long extended from handle end to spoon end. .44 inches in diameter. The handle measures 4.00 inches in length from inside to end. The bottom of handle to inside of the long shaft is 9.50 inches. Notes on the print indicate: "Finish to be black enameled at source." and "MFR'S identification must appear on this part." Unfortunately, it does not state how or where.
      • Brandon T.
        • October 23, 2008
        • 872
        Thanks Nicholas for the information.
        • Brandon T.
          • October 23, 2008
          • 872
          Thanks David, if you find out where the identification mark is suppose to be please let me know.
