C2 (66) seat adjuster - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2589
    One of the seat adjusters on my 66 is really rusted where it sits on the floor. Must have sat in water for a good period. It is likely repairable, but I don't have welding equipment and I would need to find some 12 gauge steel to repair.
    Paragon, and I suspect others, sells a replacement assembly (pictures below). If you have used one of these, please let me know if the quality and fit is acceptable.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Gene M.
    • April 1, 1985
    • 4233
    Re: C2 (66) seat adjuster
    Sounds like a swap meet, Corvette parts vendor, or e bay are best sources. As a used part be sure all the slide coils and sleeves are there so the slide action functions.
    • Stewart L.
      • March 1, 1980
      • 356
      I currently have the seats apart on a 65, the frame is bent a bit, I scouted around for a used seat frame, they are pretty expensive and many are rusted too. I am just going to fix the frame. I assume from your description its your tracks that are bad. You could always order the tracks and check them out, send them back if they aren't going to work.
      • Donald H.
        • November 2, 2009
        • 2589
        I may have to do that. I was just hoping I would find someone who has used them. I saw that Long Island sells the same replacements. I'm hoping to just repair my original.
        Don
        Don Harris
        • Greg W.
          • February 26, 2015
          • 141
          Don, we spoke a month ago , Iam not working for the next until march and can weld about anything. We are not far apart if you need a hand. Will get me away from the wifes list. Greg
