93 induction power coupler - NCRS Discussion Boards
  • Scott S.
    • July 29, 2015
    • 14
    Induction coupler came for my 93. stock has a sensor on right rear, new does not. eckler states it is correct coupler. what is the sensor and is it necessary. Air temp maybe? Can new one be modified?
  • Keith B.
    • September 15, 2014
    • 1581
    Re: 93 induction power coupler
    That's the idle air control. Or IAC sensor. Not sure but I think 92 did not have it there and it started there in 93. They might have sent you the wrong one.
      • 6940
      Jim, that is the intake air temp. sensor( IAT), and I suspect you have the wrong intake rubber duct. Keith the IAC is to the left of ( IAT )sensor.
        • 43211
        Scott-------
        Both 1992 and 1993 used the same sensor. It was originally GM #25037352 and is currently GM #12160244, aka Delco 213-243.
        The intake duct for 1992 and 1993 was the same and included the same sensor. The duct was originally GM #25099598 but it's been GM-discontinued and is scarce.
        The duct you have been supplied is incorrect. I don't know what year model it's for but it's not 1992 or 1993. I believe that 1994 and later went to a MAF sensor and used a completely different duct which would not begin to fit on a 1992-93.
        In my opinion, you definitely need the sensor. Without it, I expect you'll have a constant "service engine soon" light illuminated.
