72 insulators ????? - NCRS Discussion Boards
72 insulators ?????
  • Rey S.
    • April 1, 1995
    • 277
    72 insulators ?????
    I am in the process of assembling my Tach were as I have come across 3 what look like mounting insulators. These things are about 1" long and +/- 1/8" in dia. They appear to be made of a hard dark material (maybe just aged).
    Does anyone have a clue what these things are and what they are used for?
    Rey
    • 3422
    • Rey S.
      • April 1, 1995
      • 277
      Re: 72 insulators ?????
      OK -- This tells me that I should be able to make up some out of sticky back black foam insulation material !!! Yes?
      • Jim T.
        • March 1, 1993
        • 5351
        My experience is that they typically fall out when you separate the speedometer from lens.
          • 3422
          Hi Rey,
          If I were in need of the 'insulators' I'd look for some of the rubber spline that is used when replacing screening.
          If I could find one that I thought would work I'd buy a roll (25' ?), use 4" of it, and move the roll around in my basement until it was so stiff that I'd throw it out 10 years from now.
          • Rey S.
            • April 1, 1995
            • 277
            Hi Alan,
            Sage advice I will give it a try. I have a roll that has not reached the 10 year point yet, still pliable. I plan to cut some 1" pieces and Glue (?) them in place with a little bit of clear (maybe black)silicon rubber.
            Thanks Rey
