1962 Lower A arm stabilzer bracket - NCRS Discussion Boards
  • Kenneth F.
    • September 30, 1988
    • 282
    Is there a source for the stabilizer bracket that is attached to the lower A arms?
    Ken
    • 43221
    Re: 1962 Lower A arm stabilzer bracket
    Ken
    Ken-------
    If you're referring to the stabilizer bar LINK BRACKET which is welded to the lower control arm, it was never available from GM as a separate part. I don't know of any reproduction available today although it's possible there is one.
    • Mike T.
      • January 1, 1992
      • 568
      Ken - I see the upper a-arm is reproduced but not the lower as far as I know and since that lower sway bar bracket was welded to the arm, I kinda doubt it might be available separately. What's the story behind your 62 not having the brackets, collision damage, corrosion? The only other choice I see to connect up a lower a-arm that no longer had that bracket would be to use or fabricate a bolt-on angle bracket similar to the one I have on my 56 Nomad for an add-on front sway bar. First pic the stock setup on my 61 Corvette, second pic of the add-on bracket for my Nomad. I think I'd prefer looking around for a used lower a-arm instead of the angle bracket. You'd think there should be stock suspension components for sale from the folks adding the aftermarket front suspensions like Jim Meyer Racing.
      Mike T. - Prescott AZ.
      • Kenneth F.
        • 282
        The A-arms have the brackets, but the driver's side is broken. I do not know why it broke. I will make sure the links are correct. I will also check to see if the stabilizer bushings are not too tight. Any other suggestions would be appreciated.
        Looking for another front suspension assembly sounds like a good idea.
        Thank you, Joe and Mike
        • Eric E.
          • November 1, 1998
          • 254
          If you go looking for a used lower arm for a bracket to use, don't get concerned with left or right. The arms are the same and the only difference is the side that the stabilizer bracket is welded to.
          • Mike E.
            • February 28, 1975
            • 5138
            Ken,
            I sent you an email. Let me know if I can help.
            Mike
            • Kenneth F.
              • 282
              Eric and Mike E., The help is noted, and appreciated.
              Thank you,
              Ken
