1963 to 1967 Rear Valence Outer Bolt 121893 - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    In need of the correct 121893 bolt for the rear valence outer ends, I recalled I may have had some bolts removed from our.....(actually my wife's) 1963 Coupe when I did work on it about 8 years ago. Well, I found them....
    But I'm confused. I had them in a bag marked "original". I checked both the 1963 and 1967 AIMs, and they show a separate washer used under the head of the bolt, Item #7. Part# 121893.
    Both 1967(left 2 pics), and 1963(right 2 pics) AIMs list the same bolt part#, but with different "separate" part# washers under the head, and the same part# nut.
    Do I have original 121893 bolts here? Was there a change to this bolt within the 5 year C2 production?
    They are headmarked ELH. They have a integral washer, a protruded self aligning tip, and what appears to be a self threading or locking end. Over the years I have heard conflicting information regarding this bolt. i.e., with washer, without washer.
    This is a file photo from a thread HERE.
    Photo courtesy of Rich Pasqualone. This is from his research of the 121893 bolt. Nice Sombrero's Rich.
    Rich
  • Don H.
    Moderator
    • June 16, 2009
    • 2274
    Re: 1963 to 1967 Rear Valence Outer Bolt 121893
    Rich
    here are the bolts, washers and nuts from my Jan 64 coupe and I am 99% certain these are original.
    the washer is a separate part. The bolt is about 3/4" long.
    I bought a second set of these for my 65 from Rich P.
    • Alan D.
      • January 1, 2005
      • 2049
      On my Mar64 I have those (Photo courtesy of Rich Pasqualone) with a separate washer.
      • Enzo C.
        • January 12, 2012
        • 534
        Rich is the fastener and bolt King... Great contact for our hobby... Thanks Rich
        Enzo Colosimo
        Ncrs Ontario Chapter Chairman 🇨🇦
        ENZ-Z06/67
        • Alan D.
          • January 1, 2005
          • 2049
          Know you also discussed the washer part numbers and if individual; Here are the P.Washer specs. Other info I have (GM books) call the 63 SMALL while the later 67 as LARGE. Both of these are in Gr 8.929
          • Chester C.
            • May 29, 2013
            • 154
            Any vendor sell these bolts.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11345
              Chester, Sorry I'm a bit confused.....
              Are you asking? "...Does any vendor sell these bolts?" ?
              or are you stating? "Any vendor sells these bolts." ?
              Rich
              • Chester C.
                • May 29, 2013
                • 154
                I was asking what vender sold these but I found them thanks
