1960 283/270 - NCRS Discussion Boards
1960 283/270
  • Mike M.
    • February 26, 2008
    • 57
    1960 283/270
    What is the factory compression ratio for a 283/270hp engine?
    Thanks in advance
    • 43286
    Re: 1960 283/270
    Thanks in advance
    Mike------
    9.5:1
    • Mike M.
      • February 26, 2008
      • 57
      Re: 1960 283/270
      Joe,
      Thank you, that's what I thought!!
      I saw two other specs as well but I always thought they were 9.5:1 myself!
      Thanks again
      Mike
      • Frank D.
        • December 27, 2007
        • 2703
        Re: 1960 283/270
        Yes, relatively tame compression and they will run on 87 octane all day long if properly tuned.
        My 270hp has used nothing else for 9 years...
        • Stephen C.
          • May 31, 1988
          • 67
          Re: 1960 283/270
          Mike:all 283cu had 9.5:1 compression except for the 275hp fuel injection & the 315hp fuel injection with high lift cam had 11:1 compression.
          steve
            • 15706
            Re: 1960 283/270
            All '57 to '60 engines except the mechanical lifter FI engines had an advertised CR of 9.5:1, but depending on deck height the actual may be as low as 9:1. As stated, most of these engines will operate detonation-free on 87 PON regular unleaded, especially with the lazy centrifugal OE spark advance map, and may operate okay with a more aggressive centrifugal curve that will make more torque/power in the low to mid range.
            When rebuilding these engines, my recommendation is to increase the true measured CR to 10:1 on base cam engines and 10.25:1 on Duntov Cam engines along with an aggressive spark advance map. Premium fuel will be required, but you get more torque and power, and the increase in fuel economy will negate the increased fuel price, so the extra torque and power is basically free.
              • 15706
              Re: 1960 283/270
              The '57 to '60 mechanical lifter cam FI engines were advertised at 10.5:1.
              • Mike M.
                • February 26, 2008
                • 57
                Re: 1960 283/270
                Thanks guys!
