Correct water pump pulley for '69 with base 350 CID/300 HP motor? - NCRS Discussion Boards
  • Paul S.
    • October 29, 2015
    • 203
    Hi all,
    Like the subject states, I am trying to figure out which water pump pulley is correct for my '69 with the base 350 CID/300 HP motor. The car does NOT have power steering or AC.
    The pulley on the car right now is a 2-groove one with part number "3890419 CT" stamped on it. I thought it was original, but I am adding the A.I.R. system back to the car, and I am hearing that I need a 3-groove pulley to do so. I checked out the assembly manual, but it is still unclear to me which pulley I need.
    Can anyone help me out?
    Paul
  • Jeffrey S.
    • May 31, 1988
    • 1892
    Re: Correct water pump pulley for '69 with base 350 CID/300 HP motor?
    Paul,
    A base engine , no PS or A/C shows part #3890419 (which you have) and #3883235 for the A.I.R. belt for a total of 3 grooves. This is illustrated on page A4, UPC 6, page 196 in my copy of the AIM. Hope this helps.
    Jeff
    • Ralph S.
      • February 1, 1985
      • 935
      I just looked at a pulley I have in my basement it is # 3883235 DS came off a 1969 I used to own.
      • Paul S.
        • October 29, 2015
        • 203
        Thanks, guys -- this is very helpful!
        - Paul
          • 43258
          Originally posted by Paul Shatlock (61745)
          Hi all,
          Paul
          Paul------
          As others have mentioned, the original pulleys were a 2 groove GM #3890419 onto which was "sandwiched" a 1 groove GM #3883235 which was the AIR pump driver pulley.
          The 3890419 was discontinued from SERVICE more than 40 years ago and replaced by the GM #3995643, The latter is a virtually identical pulley, except for part number (which can't be seen when the 3883235 is installed in front of it). Unfortunately, it's been discontinued without supersession.
