62 Corvette heater hose ? - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    I know the heater hoses are 3/4" and 5/8" but what is the proper position of them.
    Intake manifold to which position at heater?
    Water pump to which position?
    Thanks.
  • Don H.
    Moderator
    • June 16, 2009
    • 2269
    Re: 62 Corvette heater hose ?
    Bruce
    If you don't have your AIM, see bottom right illustration on page 325 in your Noland.
    ps
    now that i see your part numbers on the CF post, AIM says 132 is water pump to elbow and
    989 thermostat to nipple.
    • Bruce B.
      • May 31, 1996
      • 2930
      Don, I have the AIM info but I can't find the size info based on the part numbers.
      I have looked them up no sizes are indicated.
      Bruce B
      • Don H.
        Moderator
        • June 16, 2009
        • 2269
        Bruce
        you cant tell from the size of the elbow fitting, and the size of the heater core nipple? I am a C2 guy, so not certain on your 62, but my 3/4 goes to water pump, and my 5/8 goes to intake manifold. Yours is likely the same.
          • 43247
          Originally posted by Don Hooper (50543)
          Bruce
          Don and Bruce------
          Yes, the 5/8" goes to the intake manifold and the 3/4" to the waterpump. However, as Don mentions, the nipples on the heater core should also be of different size. The larger one takes the 3/4" hose and the smaller the 5/8" hose.
          • Bruce B.
            • May 31, 1996
            • 2930
            Thanks guys,
            I got it.
            Bruce B
