'67 upper grill bracket screw - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3658
    You know you're bored when you start looking for individual screws. This bracket upper calls for GM screw #9419727. What size is this screw and what does it screw into? The bracket butts up against fiberglass and I can't tell if there is an integral washer behind the 'glass or if there is a threaded hole in the support behind the 'glass. Thanks and Merry Christmas.
    Leif
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11367
    Re: '67 upper grill bracket screw
    Leif, coincidentally, I just removed that one on the '67 the other day. It's a self tapping/threading recessed/flanged head screw. Don't have the part in front of me but I can get you some details in the morning. it screws directly into the front metal brace. I think it's a 5/16" diameter.
    These pics show it in the pile of stuff I removed. Left pic.... above left microswitch, Right pic.... about center.
    Rich
    • Leif A.
      • August 31, 1997
      • 3658
      Rich,
      Thanks for responding. I know how diligently you've been working on your '67. Coincidence you just removed that brace. If I could get an accurate description of the bolt (length, thread, size and finish), I would be most appreciative.
      Leif
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11367
        Here you go Leif....1/4" diameter, not 5/16" like I said above, pics show the rest.
        Finish was 'rust' under black paint when I removed it but likely clear zinc or cad, but maybe black phosphate?
        Rich
        • Leif A.
          • August 31, 1997
          • 3658
          Perfect!! Thanks, again, Rich.
          Leif
