70 PCV Spring Clamp Color and placement - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    I did a search and cam cup with a few threads. Two said Dark Olive Green and one on a 69 sb said Black.
    One thread also indicated there was a clamp on the carb end only. The AIM show a clamp on both ends as a Production part of the PCV hose.
    What is the correct color and placement of clamps? L46.
    Bill
    • 15638
    Re: 70 PCV Spring Clamp Color and placement
    Bill
    Bill,
    My 1970 small block has a dark green clamp on each end of the PCV hose. It is a dark enough color that I can see why some people think it is black, but it is not. Be sure you get the correct clamps with the square cut ears. Beginning in the mid-1970s the spring clamps began to have ears with rounded ends for safety reasons. The square cut ears will cut your hands if you do not treat them carefully.
    • Bill L.
      • February 1, 2004
      • 1403
      Bill,
      Thank you Terry. I was hoping you would chime in.
      I have what I believe are original clamps and the tangs are sharp and square.
      Kind Regards,
      Bill
