Hi all. I have a 66 L79 with a standard distributor. I recently had to lower the rear of the engine to remove the trans for a clutch replacement. When I tried to unscrew the tach drive cable the entire cross gear assembly came out. The tach functioned perfectly prior to this and the gear looks new. Is it possible to reinstall that assembly with the dist still in the car? Or is it best to remove the dist to reinstall it properly? Thanks for any advice or experience anyone can offer.
Mike
Mike
