1966 427 front knuckle / spindle and bearings - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1966 427 front knuckle / spindlle and bearings
    Originally posted by Patrick Cavanagh (57907)
    Joe
    Thanks Joe. Is it correct that the later spindles (69-83) also had larger bolts holding the steering arms to the spindles along with different splash shields?
    pat
    Bolts on 63-67 are 7/16". The 69 up are 1/2" bolts. I don't recall the bolt size on 68 but I think it is 1/2" too. Which means the caliper mount along with splash shields is different too.
      • 43259
      Gene-----
      1968 does use 1/2" bolts but uses the 65-67 spindle size.
      • Gene M.
        • April 1, 1985
        • 4232
        #18
        Gene-----
        Great, the old wood block on the shoulders is still working..........!
