65 BB casting mold numbers - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    There are large (I believe) mold casting numbers behind the timing chain cover on my 65 BB . I have two with the number 2 one with a 3 and one with 4X . I have seen pictures of blocks for sale on Ebay having numbers from 1 through 6 but the only number with a X was a 4 ( I have seen 4s without an X) . My question is what does the X stand for ? DSC_1916.jpgDSC_1918.jpg
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 BB casting mold numbers
    Bill -- FWIW, here's a "1" on the front of my 2-bolt 396 "3855961", casting date mid May. Not sure what the significance is.
    c
    • Carl N.
      • April 30, 1984
      • 592
      No idea - when I can get thru my junk I'll look at my spare blocks and see how they are marked -
      • Jerry W.
        • January 27, 2009
        • 588
        seems like a previous post said "x" means first run for casting
        • Wayne L.
          • September 30, 1981
          • 233
          Yes, "X" usually means the first run of a new casting. I have "heard" that the numerals indicate which casting line the part was cast on. All for quality control.
            Wayne -
            Those numerals normally indicate the pattern number the sand mold was made from - high-volume castings always had multiple patterns that produced molds, and they were numbered for traceability in the event of casting or machining problems.
            • Wayne M.
              • March 1, 1980
              • 6414
              ......Those numerals normally indicate the pattern number the sand mold was made from .....
              Here's the back end of the same 961 block that I showed in post #2. It's got an 'X' and mold # 3 (versus mold #1 and no 'X' on the front).
                • 43246
                [ATTACH=CONFIG]67165[/ATTACH]
                Wayne-----
                There were different elements to each pattern set. The elements were often "mixed-and-matched".
                • Don H.
                  Moderator
                  • June 16, 2009
                  • 2269
                  As a tribute to Bill, I'll stick what was Bill's last thread on his beloved L78 cars.
                  • Carl N.
                    • April 30, 1984
                    • 592
                    Don, many thanks, Bill would be pleased.
                    • Enzo C.
                      • January 12, 2012
                      • 534
                      Good job Don... He deserves the respect
                      Enzo Colosimo
                      Ncrs Ontario Chapter Chairman 🇨🇦
                      ENZ-Z06/67
