63 327 block ID - NCRS Discussion Boards
63 327 block ID
  • Michael G.
    • November 12, 2008
    • 2158
    63 327 block ID
    The pic below is of the pad of a 327 block cast in Jan, 63. I'm wondering if these are original stampings or something the re-builder did. If its original, what the heck did it come out of? Thanks
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • 43290
    Re: 63 327 block ID
    [ATTACH=CONFIG]66995[/ATTACH]
    Mike-------
    The "040" was added, most likely be a rebuilder. It probably refers to the overbore (i.e. 0.040").
    If the "S" suffix is not followed by any other letter unseen in the photo, then the engine is a 327 cid, 250 HP originally installed in a 1962-64 passenger car with Powerglide.
    Also, the "6 18 77" looks more like a date than an VIN derivative. Most likely, it's the date the rebuild was performed by the rebuilder.
    • Frank D.
      • December 27, 2007
      • 2703
      Re: 63 327 block ID
      Agree with all of the above!
      • Michael G.
        • November 12, 2008
        • 2158
        Re: 63 327 block ID
        Thanks Joe, the S is the last letter, so 250 passenger it is...
        I thought the VIN derivative looked like a date, but the font looks about right. Not sure how that date ends up over the branch marks, though???
        Mike
        • John D.
          • December 1, 1979
          • 5507
          Re: 63 327 block ID
          I think Joe is spot on with his answer. Good one Joe. John
            • 43290
            Re: 63 327 block ID
            Michael-------
            It's possible that this engine did not originally have a VIN derivative stamped on the pad. Less likely, but possible, is that this was originally a complete SERVICE engine for the above-referenced applications and had no stamped VIN derivative.
            • Michael G.
              • November 12, 2008
              • 2158
              Re: 63 327 block ID
              Joe, I'd probably go with the first option, i.e., no VIN derivative on a 250 passenger engine. The heads are low-horse type, so that matches. The date seems to be of similar size (and the font is similar) to the font of the "040" stamp, so maybe the rebuilder did stamp the date during a 1977 re-build.
              Well, if anyone's looking to see original 1963 broach marks and stamp font, this is probably not a stamp that someone would have faked for any reason, so there you go...a good example...
              Now, what do I do with it?
              Mike
              • Timothy B.
                • April 30, 1983
                • 5203
                Re: 63 327 block ID
                Michael,
                The cast date on the back will give a indication of the best fit for the year car.
                Simply put, if it's a Flint block (which it is) and a 870 cast block (which it probably is) it can service perfectly the car made in the casting year of the block. The assembly date is February so the cast date may be A?? or even L?? of the previous year that best fits the car.
