My '65 coupe headlight hi/low telltale light glows very dimly whenever the lights are on (hi or low) and glows brightly when the hi beams are selected.  I have removed the dimmer switch from the circuit to try and isolate the problem further and when powered up, with the lights on the telltale still glows very dimly.  Is it possible that I am seeming some bleed over of light from one of the adjacent dash lamps or should I suspect something more may be going on here?
Thanks in advance
Jim
					Thanks in advance
Jim
