1970 Corvette Convertible Frame Pictures - For Reference - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi All,
    Looking for pictures of an unrestored or NCRS correct restored 1970 Convertible frame. Prefer LT1.
    Looking for references and information on how to detail correctly as well as the way you differentiate a 1970 frame from an early or later frame.
    Thanks in advance,
    Dave
  • Ed H.
    • November 19, 2015
    • 192
    Re: 1970 Corvette Convertible Frame Pictures - For Reference
    Folded OK?
    • David S.
      • August 9, 2009
      • 595
      Originally posted by Ed Harrow (61788)
      Folded OK?
      Sorry - Frame as in Chassis not convertible frame.
        • 3422
        Hi David,
        I don't think there is any difference between a coupe and convertible frame and running gear.
        But since you mention you're interested in a LT-!, that means it WOULD be a 4-speed frame.
        I believe early 68 frames will not have the 2 diagonal braces at the kick-up/cross member while later 68 and 69+ frames have the braces. Later 69 and 70+ frames would have 2 drilled holes in the trailing arm pockets for a alignment shim cotter key. A frame WITH the braces but WITHOUT the holes would be an earlier 69 frame.
        Would you be willing to look at pictures taken from below with the body in place?
        Are you interested in the running gear too or just the frame?
        • Paul O.
          • August 31, 1990
          • 1716
          Here is one that I have unrestored but of a 1969. A few of other areas of several frames.
          • David S.
            • August 9, 2009
            • 595
            Thanks all.
            Alan - I'm interested in any and all I can get my hands on. Must be original though (unrestored or restored correctly).
            Paul - Thanks for the pics!
            Best,
            Dave
            • Ed H.
              • November 19, 2015
              • 192
              If you are patient - I have a 70 LT-1 roadster that's heading to the beauty parlor for a makeover late this month or early next.
                • 3422
                Hi David,
                There are quite a few chassis photos available of a very low mileage ZR-! taken a few years ago at the Winter Regional and then again at the Convention in Charlotte.
                It's a 72 however not a 70 as you specified in your first post.
                Might those pictures still be of interest to you?
                • David S.
                  • August 9, 2009
                  • 595
                  Main interested in how to identify an original 1970 frame. If 70 and 72 are the same then I'm interested!
                  Dave
                    • 43287
                    Dave
                    Dave------
                    They were of different part numbers. However, I really think the differences were extremely minor and I doubt there are many folks who would even know the differences. It would probably take a GM drawing of the various 1969-72 frames to find out just what the differences were.
                    My guess is that you could put an original 1970 and 1972 frame side-by-side and one would have a difficult time discerning the differences.
                      • 3422
                      Hi Dave,
                      If still readable wouldn't the first digit of the sequence number stamped in the frame rail in 2 places indicate what year the frame is?
