Engine misfire/cutting out - NCRS Discussion Boards
  • Brenton M.
    • May 31, 2006
    • 66
    65 396/425 After driving my car for a while on yesterday it started to misfire and cutout upon acceleration, the engine finally stalled out, we had to jump it off, while trying to restart the engine I noticed smoke coming from my side exhaust pipes. It seemed to be flooded with gas. After getting it started it ran fine under normal conditions, but every time I would really accelerate it would cutout and sometime backfire through exhaust. I pulled the spark plugs and found six of them was wet with gas. I'm running R45XLS. Please help!!! this has been going on for a while.
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Engine misfire/cutting out
    Well - I'd say to go through the usual troubleshooting steps -- carb, distributor, coil, plug wires and plugs.
    Don't discount the midyear "red wire syndrome"....meaning corrosion at the bulkhead connectors near the bottom of the brake master cylinder in the engine compartment.
    • Keith B.
      • September 15, 2014
      • 1587
      Frank sounds more like a timming issue and vacuum advance not working.
      • Frank D.
        • December 27, 2007
        • 2703
        Possibly - but there has been a couple of cases of mysterious backfiring on midyears the last few months and it turned out to be bulkhead connector issues.
        • Douglas L.
          • May 8, 2015
          • 181
          What do you mean by "jump it off"? Do you mean that after it died it wouldn't crank over and had to be jumpstarted with jumper cables to restart?
          • Carl N.
            • April 30, 1984
            • 592
            Possible stuck float on primary bowl or faulty accelerator pump or "tip" in setting on pump. Also have you adjusted valve lash in the past.
            • George W.
              • July 31, 1998
              • 322
              The '65 396/425 should have TI; the "misfire and cutout on acceleration" issue sounds like a timing problem. I have seen the 396/425 TI system run good on slow/normal acceleration, but when you punch it the engine cuts out or misfires; this can mean you need more total advance. I would start with timing advance.
              Get the engine to run and then look into the fuel concern. Good luck.
              Dr. George
              • Brenton M.
                • May 31, 2006
                • 66
                Thanks Frank. I did a total frame off restoration on the car in 2008 including engine rebuild, all new wiring harness, etc. It's been about a year since I adjusted the valves and checked the timing. I haven't put many miles on the engine since the rebuild maybe 300 miles. If I remember correctly it did this once before, I think it was a timing issue. The part that I don't understand is that it runs fine for a while, until engine really warm up.
                • Leif A.
                  • August 31, 1997
                  • 3641
                  Brenton,
                  Odds are it's the ignition coil. To me, when you say "it runs fine for a while, until engine really warms up" indicates a failing coil. Go to your local FLAPS and pick up a coil (fairly inexpensive) and give it a try. May save you a ton of time and angst.
                  Leif
