A arm rivet bolts, ( 1967) - NCRS Discussion Boards
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 993
    Re: A arm rivet bolts, ( 1967)
    Dave, I sent my A-arms to Marco Hartner who did a great job of riveting my NOS ball joints onto my 1965 A-arms. It was well worth the expense. Your call though, Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
    • Donald H.
      • November 2, 2009
      • 2591
      I used the rivet looking bolts on my 67 driver upper and lower and did not have to drill them. I thing I got them at Paragon or Corvette Central.
      For my 66 coupe, which I am restoring to be judged, a friend and I set rivets. We did them cold (no heat) and they turned out very good. We used a heavy duty air hammer with the rivet setting attachments. If you or a friend has a heavy air hammer, the attachments are available on Ebay or Amazon and are about $30.
      I did build a jig for bucking the rivets, similar to the ones in the Restorer article. I used an old chisel cut flat with with a dimple drilled in it for the uppers. The lowers are a little harder to get to. I used a piece of 1/2" thick plate steel, also with a dimple. But If you are not that particular how the inside head looks, it can be done without special jigs.
      Don
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Dave C.
        • March 20, 2014
        • 253
        #18
        Thanks very much Don, I figured out that it was just the buildup of powder coating on the lower arms that was binding the bolts ( they are the only part of the car that I powder coated, they were a tad rusty, and I wanted them to look nice and smooth, please don't judge me) as for the upper arms , the rivet style bolts they provided definitely require drilling, so I am going to try to rivet them, my friend has the tool for the air hammer, and I will try your trick with the chisel. As I mentioned the lower ball joints did not come with the proper rivets, so I was thinking of bolting them in , then dye grinding the inside and welding a nice round bead on the end to look more like a rivet.
        • Gene M.
          • April 1, 1985
          • 4233
          #19
          Sounds like more effort than just riveted correctly............ no?
          • Donald H.
            • November 2, 2009
            • 2591
            #20
            If you decide to get correct rivets for the lowers, I would suggest getting them from LIC. I bought two sets, one from LIC and one from Paragon. The Paragon ones were longer and needed to be cut down some.
            DOn
            Don Harris
            • Dave C.
              • March 20, 2014
              • 253
              #21
              I know Gene, but as I mentioned, the lower ball joints did not come with the rivets, and I am in Canada so it takes about a week to get anything delivered.
              • Gene M.
                • April 1, 1985
                • 4233
                #22
                Dave,
                I got rivets at the local tractor supply.
                • Dave C.
                  • March 20, 2014
                  • 253
                  #23
                  Hey good advise Gene, maybe I'll try that, just finished the uppers, I made a buck out of a 3/4" bolt, and cut the end off of one of my air chisel bits and concaved it with a die grinder, but the tool just didn't have the power. Went over to my neighbors truck repair shop and borrowed their $800.00 Ingersoll Rand , did the same treatment to one of their tools and 10 minutes later they were done!
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    #24
                    Dave,
                    I can email you my restorer article if you send an email to me at crisler@wheatstate.com
                    Tracy
