2003 Anniversary Edition Wheels: Valve Stems and Caps - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2039
    A friend asked this question, and I told him I'd try to find an answer.
    He has a nice, low mileage 2003 Anniversary convertible, bought from the original owner.
    It has the "champagne" or "goldish colored" factory wheels.
    The PO had the tires filled with Nitrogen. When they did this, they replaced the original valve stem caps with green plastic ones, to denote the Nitrogen fill.
    What color and material were the original caps for these "gold tone" wheels?
    Were they plastic or metal?
    Were they gray, silver, black, "gold", etc. ?
    TIA.
    Chuck
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 2003 Anniversary Edition Wheels: Valve Stems and Caps
    Chuck
    Here is a photo of an 2003 gold hue wheel. 155 miles on this car the stem is metal but the cap maybe gold hue colored plastic.
    • Chuck G.
      • May 31, 1982
      • 2039
      Thanks, Paul.
      Sorta looks like a gold-ish tint, but could also be silver. Definitely looks like the thin, plastic caps seen on other GM cars of the era..
      • Doug J.
        • April 1, 2005
        • 140
        Chuck,
        That wheel pictured is not the correct wheel for a 50th Anniversary car...but in answer to your question, the caps are silver, and are made of metal.
        • Chuck G.
          • May 31, 1982
          • 2039
          Originally posted by Doug Jorgensen (43687)
          Chuck,
          What is the difference between the wheel pictured and the 50th Anniversary "champagne" wheel?
          This pic of the cap was posted over on Corvette Forum.
          • Doug J.
            • April 1, 2005
            • 140
            The center cap is different, the 5 spoke design is different, the outer circumference design of the wheel near the tire is different. The cap pictured is the correct design, by the same manufacturer, the ones on my 50th and the ones on my neighbors are silver.
              • 43277
              Originally posted by Chuck Gongloff (5629)
              Thanks, Paul.
              Chuck-------
              IF it was ever available in SERVICE, it was/is GM #25731359. This cap, still available from GM, will definitely work but whether it is configured exactly like the original, I do not know.
