1967 Rallye Wheel Center Cap Ornament Restoration - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11339
    This is a extension of a thread......Here.
    I'm preparing to paint these ornaments and I'm masking the Chevy Bowtie. If a light dusting of gold is applied to the concentric circle area, will this also hit the sides of the bowtie? Or should the sides of the Bowtie be masked to be clear of any materials?
    For informational purposes, I will describe my just discovered research showing the differences between original ornaments and reproductions. I also have a set of reproduction center caps and ornaments, subtle but clearly different also. I bought these repros just to get the ornaments some time ago but since I located original ornaments and had them chromed, I will be returning the repros to my vendor.
    here are the comparisons....Original left, repro right. The separate ornament is the original.
    original
    repro dish curve compared to original dish curve. Quite different.
    Another view of the same, repro left, original right.I loosley placed the original ornament on the original cap)
    Comparison of original dish curve(left) to repro dish curve(right)
    original cap and ornament
    original ornament left, repro right....in each pair of photos.
    original circular bar is 0.100" wide, 0.140" on reproduction. Judges get out your vernier calipers next time out.
    edit. Added more comparison photos of repros vs originals....
    Repro
    Left original. Right repro. (I had this reversed earlier and just fixed it) The angle of the top surface is higher on the repro.
    Left repro. Right original. Repro edge is more rounded the the original to the right.
    Left repro. Right original. Totally different "S" font.
    At least we have repros available, albeit some subtle difference when looking closely.
  • Robert L.
    Infrequent User
    • March 1, 1989
    • 10
    Re: 1967 Rallye Wheel Center Cap Ornament Restoration
    Richard, I use a yellow Hi-Liter with a pointed tip. Once applied (none to the edge of the bow-tie), lightly rub some off to get the "gold translucent hue" you desire. It tends to never dry and also smears, but you could seal it with some matt clear. Robert
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11339
      Robert, That's a good idea. But I just finished one with a dusting of gold I have here. I dusted it on straight on from the front with the cap resting on edge. This way it kept the gold off the sides of the Bowtie also. What do you think?
      Here are the steps from start to finish.... I used alcohol to clean the lettering crevices and circular rings, masked, applied black, rubbed the flat areas with acetone to remove the black above the lettering, masked again for the gold dusting, done.
      PC110003.jpgPC110004.jpgPC110005.jpgPC110006.jpgPC110007.jpgPC110010.jpgPC110011.jpgPC110029.jpgPC110030.jpgPC110031.jpgPC110032.jpgPC110033.jpgPC110034.jpgPC110035.jpgPC110036.jpgPC110037.jpgPC110038.jpgPC110039.jpgPC110040.jpgPC110041.jpg
      • Gene M.
        • April 1, 1985
        • 4232
        Rich,
        I assume you want to reflect the poor chrome job GM did on originals. I just went and looked at my 67. The goldish look is only in the circular rings around the bow tie. Looking at your photo you need to dust the gold spray a tad bit lighter. The Gold hue is slight. Otherwise looks good. I've covered this center cap issue in my judges training but showing a correct representation of the gold hue is always a problem. This level of detail is commendable.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11339
          Originally posted by Gene Manno (8571)
          Rich,
          Thanks Gene, Rats......actually I went the other way on the other 3 ornaments. Just finished. The first one looked a little light so I dusted it again.
          I will remove it all before it dries and do all 4 lighter again. Before I had them chromed I had a picture somewhere and it seemed dark. I'll see if I can find it.
          My Chrome Shop had it and just sent it to me. I see what you mean. back later after the fix....Thanks
          Rich
          • Keith B.
            • September 15, 2014
            • 1591
            inst the gold hue your trying to replicate just the base in the flashing chroming wearing though after all these years in service?
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11339
              Keith, I would not think so, as the entire ornament would have that goldish hue feature. Allegedly they could be either gold or not according to the JG. Here is a old thread I researched before embarking on this journey.
              https://www.forums.ncrs.org/showthre...+ornament+cap+
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11339
                Okay, I stripped all 4 of their gold and started over on one.
                Very light spray, but still seemed too much in comparison t the original photo before chroming.
                I wiped it off and dusted agin, even lighter.
                Then I used a q-tip and wiped just the ridge tops
                Comparison left gold, right none.
                Comparison to the original
                The photos come out more gold than by eye in person.
                I've spent a substantial amount of time on this effort, but I think I'm done.
                • Robert L.
                  Infrequent User
                  • March 1, 1989
                  • 10
                  Richard,
                  Appears as though you really put some time and effort. From the pics, they look great!
                  If you're inclined and have a spare center cap (just for comparison), try the yellow marker process to compare the goldish hue.
                  Regards, Robert
                  • Donald O.
                    • May 31, 1990
                    • 1593
                    Nice eye for the details.
                    Don
                    • Leif A.
                      • August 31, 1997
                      • 3645
                      As always, Richard, exceptional attention to detail. FWIW, pics of one of mine...appears the "gold" tint is on the sides of the bowtie, as well. Amazing how a digital close-up shows so many flaws...no wonder the gals hate close-ups
                      Leif
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11339
                        Thanks gents....
                        Yes Robert I like your idea too. I'll try that on the next ones. Does it last? I'm wondering how long the paint can last.
                        Leif, great pics, thanks. Interesting that yours now show the gold there on the bowtie sides. Mysterious. Can you see if it's actually a paint product or is it the metal itself? Inherently, when dusting the faces the sides get ht a little too. Only caveat is where did yours come from and if someone restored them before, etc.
                        Rich
                        ps I hope some of the judges here enjoyed this little info-tidbit of information. I certainly learned much and thanks to all for sharing and helping me with these little critters. It's great to be able to preserve nice original "USA" parts.
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11339
                          Wheel Parts Mockup. All GM parts. Also some details of the little pieces, complete with Argent Silver paint sags just like original.
                          The 3 year old reproduction 7.75x15 Goodyears will be off of the repro bolt-ons and on these wheels soon. Can't wait.
                          PC120001.jpgPC120002.jpgPC120003.jpgPC120007.jpgPC120008.jpgPC120009.jpgPC120016.jpgPC120019.jpgPC120020.jpgPC120021.jpgPC120022.jpgPC120023.jpgPC120024.jpgPC120025.jpgPC120026.jpgPC120027.jpgPC120028.jpgPC120029.jpgPC120030.jpgPC120031.jpgPC120033.jpgPC120037.jpgPC120034.jpgPC120036.jpg
                          • Leif A.
                            • August 31, 1997
                            • 3645
                            Thanks gents....
                            Rich
                            Rich,
                            Even with my "cheaters" on and a magnifying glass it's virtually impossible for me to tell if the gold on the side of the bowtie is paint or the metal. It doesn't "feel" like paint yet I can't imagine what type of metal would be gold tone so it must be overspray. I believe these caps to be original to the car and never restored. Now, I wonder what the original process was to apply the gold tone. Certainly it wasn't done with the pains taking detail you applied so some type of mass manufacturing.
                            Leif
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11339
                              Leif,
                              Thanks for checking. I wish I had checked the originals more carefully before I sent to chrome. I'm satisfied with the results but was curious.
                              Rich
