I removed the 4 screws that attach the pump.....and dropped one onto the bellhousing, two days later I still haven't found it although I'm sure I will figure something out.
I then detached the two wiper arms that connect to the motor under the dash, and proceeded to remove three of four screws attaching the motor to the front panel. I only removed three as I have yet to find the fourth. However I am getting to be quite certain that while I can see the fourth hole for the screw no screw was in there. The motor does not budge, wiggle, lift at a corner.....nothing. Its like it was bonded to the panel. Since I would like to remove the motor without damaging the panel, I'm stumped as to how.
The body is on the frame and the engine is in and the car is sitting on all four tires. The heater system, glove box, and clock are out.
Anyone have any solutions? I am unable to get a putty knife between the panel and the motor as the location of the motor prohibits it from the motor side and I don't know what I could used from the interior side.
Don
Don
