Power Steering Control Valve - 63 - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    While storing the 63 in the back of the garage there was a trail of P/S fluid on the floor. I checked and the pump was empty.
    Since I can't get under the car to look, are there any numbers, dates, codes, etc. on the P/S control valve? If not I'll just get another from Lonestar Caliper or another provider, else I'll rebuild the original. Who's the best at rebuilding the originals?
    Comments recommendation welcome....
    Thank
    • 6956
    Re: Power Steering Control Valve - 63
    Harry, I have a reman control valve in my garage and looked to see if there is a date on it and cannot find one. just a casting number. although I have no idea if 63 may have a different casting number.
    • Bob R.
      • June 30, 2002
      • 1595
      Harry,
      There are three o ring type seals on the pump that may be the cause of the leak. I replaced the o rings on my pump several years ago. I also found a donor pump body at Carlisle and replaced that as well. I think it was common to use a pry bar when putting tension on the belt and denting the pump case thus causing a leak. I tried to knock out the dents but it always leaked until I replaced it. Now I noticed the bottom of the PS pump is wet but never seems to drip.
