Got all the parts together to make the bearing remover that uses an inverted 3" electrical box over the bearing then stacking washers, pipe, coupler and 3/4" bolt and nuts.... etc that was originally posted by Rich Mozzetta. Got everything in place and tighten up the bolt. The more I tightened the nut the electrical box started to cave in a bit.  That was to be expected since the one copied did the same thing. Then the box flaired over the edge of the 3rd arm casting and that finished the attempt. The bearing didn't move. (Yes, the retaining ring is out).
My next thought is to exchange the electrical box for some 2 1/2" I.D. steel tube and try again.
i have soaked the bearing in anti-seize lubricant. Other than that, any other suggestions?
thanks, Eric
thanks, Eric
