How many different numbers/codes on the differential & cover? This is for a 1971.
1. Differential cover would have #3871375. This was used from approx 1964-1977. My casting date is A 17 8 but the car was built in January 1971. That doesn't seem to fit. How would you know if it had a "6" whether it was 66 or 76? Some earlier year had casting dates on some but not on others.
2. The differential also had a casting number---for 1971--it was #3899143. Was there also a casting date? If so where is it.
3. The number for the rear end gear ratio. Mine is hard to read but appears to be AA (3.55 gear); W; 341--day of the year (December 7), E--source, and 2--the assembly shift. Is there supposed to be a number which indicates the year it was made?
How close is the differential and/ differential cover date supposed to be to the car build date?
Did I miss any other numbers of the differential or cover?
