1963 T-10 Lubrication - NCRS Discussion Boards
  • Martin M.
    • November 1, 1979
    • 124
    I have finally found someone in my small town who is willing to work on anything, To whit, we are changing the engine in my nom '63 coupe. Pulled engine & tranny and carelessly let most of the tranny lube drain out on the floor. Since I haven't been able to do much in the shop lately, and my 82 year 'little gray cells' are fewer & fewer I NCRS. So..... Can anyone tell me the correct replacement fluid for a T-10 from a '63??
    TIA, Marty
    Beautiful Pahrump, NV.
    No smog, no rain, no winter, no hurricanes, no tornadoes,
    no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
    vetteheads.com alumni, Boston MA alumni
    1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
    1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
    1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
    1957 Chrysler 300 C 392 Hemi Car
    All for sale - most not cheap!!!
  • Joe R.
    • July 31, 1976
    • 4550
    Re: 1963 T-10 Lubrication
    Marty,
    You still haunting area 51????
    On the trans you may use any 90-110 Transmission fluid but since it is well broken-in I would purchase synthetic from the GM dealer.
    JR
      • 15667
      SAE 80W-90 GL-5. Brand makes no difference. Just look for the referenced information in the API "donut" - usually on the back of the bottle. Any auto parts store should have this common product in stock.
      80W-90 GL-5 is the modern equivalent of the Mil-L-2105 spec oil that was original fill as specified in the owner's manual and shop manual. The mil-spec was canceled at least ten years ago and replaced with the API spec.
      • Martin M.
        • November 1, 1979
        • 124
        Thanx Guys. I can probably find one or the other here in Pahrump. I am planning on driving this car next week! It has a new 350 in it, but the car itself hasn't been driven in 25+ years . I don't know what to expect, but we shall overcome.
        Joe, Area 51 is under control. Be very careful what you say about it. or there will be a knock on your door in the middle of the night, and it won't be me.
        Happy Holidays to all
        Marty & Barbara
        • Martin M.
          • November 1, 1979
          • 124
          In a related subject, what should I use in the rear end. I assume it's a posi but ????
          Marty
          • Joe R.
            • July 31, 1976
            • 4550
            Marty,
            Same stuff but be sure to add at least one bottle of posi trac lube from the GM dealer.
            JR
            PS. Area 51 is not included in this post!
            • Martin M.
              • November 1, 1979
              • 124
              Thanks Joe.
              Marty
                • 15667
                You can also buy the Positraction additive from NAPA - probably cheaper than a GM dealer - NCB 4285V, 4-0z. bottle.
