Head lights '67 corvette - NCRS Discussion Boards
  • Bruce A.
    • August 18, 2015
    • 29
    Guy, I'm reworking my previously damaged front end and I'm trying to determine what the margins (gaps) should be on the sides and at the back on my flip-up headlight cans.
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: Head lights '67 corvette
    Bruce, The gap is pretty consistent on all sides at about 5/32". Note: The corners are radius, NOT square cut....
    Photo of original bucket.......
    • Stewart L.
      • March 1, 1980
      • 356
      The Assy manual calls for .06 to .20 or 1/16 to 3/16. Stephen's headlamp looks real nice.
      • Wayne W.
        • April 30, 1982
        • 3605
        They are typically closer on the outside than the inside.
        • Gene M.
          • April 1, 1985
          • 4233
          The side to side gap is locked down with the collar and set screw. The top edge is set by the position of the two spherical bearings positioned by the three screws on each mounting.
