Who sells correct 3x2 fuel line blocks? - NCRS Discussion Boards
  • Mark G.
    • January 31, 2007
    • 177
    I purchased a set of fuel lines for my 69 435 car. The brass blocks don't have the recess between the pipe connections. Does anyone sell the correct ones?
    Mark
  • Patrick N.
    • March 10, 2008
    • 954
    Re: Who sells correct 3x2 fuel line blocks?
    Hi Mark, you might want to give America's Finest Corvettes a try. I thought I had lost one of my blocks during the restoration and gave them a call. They said they might have some, but I found my block later that day and called off the search.
    Worth a try, good luck!
    Pat
    • Mark G.
      • January 31, 2007
      • 177
      Thanks Pat. I'll look them up.
      Mark
      • Frank T.
        Infrequent User
        • March 20, 2013
        • 26
        Corvette central
        • Mark G.
          • January 31, 2007
          • 177
          All the ones I've found are squarish, without the recess between the metal pipe connections. They are also stamped "eaton". I thought they should have the "w" logo.
          • Wayne M.
            • March 1, 1980
            • 6414
            Here's an original tee, with the Weatherhead marking.
            • Mark G.
              • January 31, 2007
              • 177
              Wayne, that's what I'm looking for. Seems "reproduction" parts aren't really reproduction at all, just something similar in appearance that will do the desired function.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11334
                Frank is correct Corvette Central sells them, but unsure if separately. The entire line kit is here....
                Note this set I have here soon to be reinstalled. It has 2 different sizes of the mark.
