1963 Borg-Warner T-10 Date Codes - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 1963 Borg-Warner T-10 Date Codes
    I agree with Loren on or about 15000.
    • Loren L.
      • April 30, 1976
      • 4104
      How about May?
      • Richard G.
        • July 31, 1984
        • 1718
        #18
        I stand corrected.
        I was thinking the beginning was the end!
        It's usually my wife that catches me!
        Thanks Loren.
        • Gerald C.
          • June 30, 1987
          • 1299
          #19
          So.....my April 8, 1963 with a 3:36 non-posi should or should not have a transmission tag? If so, what should the tag read?
          • Thomas B.
            • October 11, 2021
            • 299
            #20
            Her's a pic of my stamp on a Feb 18, 1963 production date. I believe it to be a close ratio but tag is missing. I believe should be tagged R-R, S-S, or T-T according to NCRS pocket guide.
            • Gerald C.
              • June 30, 1987
              • 1299
              #21
              Thanks Tom!
              • Steve E.
                Infrequent User
                • August 31, 2020
                • 25
                #22
                I have a similar thread that I started information seems conflicting. To answer your original question, yes you need a tag. At my last regional judging event the response was it just needs a tag rather than something specific. I have not read or seen a response that seems definitive on this subject.
                • Harry S.
                  • July 31, 2002
                  • 5330
                  #23
                  Early 63 T10. I'll look for a later tag. I do believe they changes to all numbers on the tags on later T10's.
                  • Gerald C.
                    • June 30, 1987
                    • 1299
                    #24
                    Well, I think I solved the dilemma of the data tag. I have attached three separate data pictures which indicates that my data tab on the tranny should be "QQ", I think.
                    1. In the specifications Chart, it shows a "QQ" should be used with the low gear of 2.54. However, it does state "early" cars and yet mine is an April car, which many consider "late".
                    2. Under the 1963 Power Team description, the 1st gear should be 2.54 for the 4 speed and the L75 300 HP
                    3. Also, in the Shop Manual it reads a low gear of 2.54.
                    4. So all indications are that if it does represent a 2.54 low gear, it should have a "QQ" data tag on the tranny.
                    Am I correct in my assumptions? Please see the attached pictures.
                    Thanks1963 BW Data Tab Info.jpg1963 Power Team Data.jpg1963 Transmission Data.jpg
                    • Steve E.
                      Infrequent User
                      • August 31, 2020
                      • 25
                      #25
                      Yes, that looks correct. It appears we are the same. My car is 4th week of March 63 build.
                      Steve
                      • Gerald C.
                        • June 30, 1987
                        • 1299
                        #26
                        Which vendor makes these data tags that state "QQ"?? But states for an "early car"
                        • Thomas B.
                          • October 11, 2021
                          • 299
                          #27
                          • Thomas B.
                            • October 11, 2021
                            • 299
                            #28
                            Would this tag be correct? CC claims to be correct prior to vin #12000.
                            • Thomas B.
                              • October 11, 2021
                              • 299
                              #29
                              Pic from Assembly Manual. Tag numbers in my previous reply matches the trans case number for RPO L76 - L-84. Did this replace the double letter tag code at some point? Or should this tag be on the trans in addition to a double letter code?
                              • Bob J.
                                • December 1, 1977
                                • 716
                                #30
                                No.
                                As I posted years ago, there were different tags for 1963 close ratio T10s.
                                The speedometer drive gear (inside the trans) was different depending on which rear end ratio the trans was used with.
