64 Ignition Shield Installation - NCRS Discussion Boards
  • Edward C.
    Infrequent User
    • August 27, 2014
    • 3
    My question involves the orientation of the left rear spark plug shield and the left spark plug wire shield. Does the 'tab' on the rear of the plug shield go up inside or stay outside of the wire shield? I've seen it done both ways. The assembly manual, section U69, appears to show the 'tab' oriented to the outside of the wire shield.
    • 6956
    Re: 64 Ignition Shield Installation
    Ed, the tab is on the outside of the vertical shield.
    • Edward C.
      Infrequent User
      • August 27, 2014
      • 3
      Ed, thanks for answering my question. I've had many discussions about this with other owners, with most absolutely positive that the 'tab' goes inside the vertical shield.
        • 6956
        Ed, At my last regional I was dinged for having mine on the inside. Which I also thought was correct.
        • Gene M.
          • April 1, 1985
          • 4233
          When I'm not showing my cars NCRS it's on the inside, because it looks much better that way. When on the flight field it goes outside to avoid the discussion.
