GM rod and Main Numbers - NCRS Discussion Boards
  • Anthony P.
    • October 26, 2011
    • 199
    Today I was able to remove the pistons and Crank, from my 66 427/390.. Looking to see if the #s on the brg shells are original?
    Rod Brgs. GMM 420
    57831
    30185
    Main Brgs 52894
    001
    267M5
    Joe L What if any useful info is this? What do the old parts books say?
    • 43277
    Re: GM rod and Main Numbers
    Rod Brgs. GMM 420
    57831
    30185
    Main Brgs 52894
    001
    267M5
    Tony-----
    None of these numbers are GM part numbers or, apparently, derivatives thereof. However, I believe the rod bearings are original-----the "GMM" denotes General Motors-Moraine. The main bearings may or may not be original. Here are the original GM part numbers:
    main bearing positions 1&2-----GM #3885380
    main bearing positions 3&4-----GM #3876080
    main bearing rear----------------GM #3876085
    rod bearings----------------------GM #3876091
    One note of caution, though: all of the above are standard size bearings which is what the factory generally uses. However, sometimes a non-standard size bearing is used for one or more positions.
    • Anthony P.
      • October 26, 2011
      • 199
      Joe, I forgot to state that the mains also have the GMM 420 as well. I will bring home a micrometer from work tomorrow and get a measurement of all journals before I order new brgs.
      Anybody pros/cons on the Clevite P series brgs?
      Thanks Joe
        • 43277
        Thanks Joe
        Tony-------
        My preference: Federal-Mogul Premium Aluminum (AP-series). These are equivalent to original GM.
        • Anthony P.
          • October 26, 2011
          • 199
          Ok thanks Joe, I just looked on their e catalog and found the A series, have not found the the AP series yet.
