1971 front & rear Brake Caliper Correct Color - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    Re: 1971 front & rear Brake Caliper Correct Color
    Any one have pictures of the front & back after painting?
    • Gary B.
      • February 1, 1997
      • 7053
      And the bolts holding the caliper halves together were not painted.
      Gary
        • 11669
        #18
        Originally posted by David Warzala (59450)
        You might consider a ceramic caliper semi-gloss paint versus a non heat resistant paint. I found that the gloss subsides after a number of heat cycles assuming you are driving the car.
        I've used the black caliper paint (VHT, I believe) and it worked quite well.
        • Paul C.
          • November 12, 2007
          • 511
          #19
          I can post pictures of someone tells me how.
          • Paul C.
            • November 12, 2007
            • 511
            #20
            Turns out the caliper I have are the incorrect numbers for the car so I stopped rebuilding them--although they looked great. I have someone who will sell me these rear calipers that were for a 72 and purchased 20 years ago. Do these look original or are they reproductions??? Any way to tell? Need to know before purchasing.
            • Gary B.
              • February 1, 1997
              • 7053
              #21
              Paul,
              I wasn't aware there were reproductions.
              Gary
                • 11669
                #22
                Originally posted by Gary Beaupre (28818)
                Paul,
                Gary
                Lone Star has been making new ones for a few years now. I believe they are using the original molds.
                I have installed them on one car, and of course there were no problems since they are essentially identical parts.
                  • 11669
                  #23
                  No easy way to tell, but these have obviously been repainted.
                  Given the evidence of paint over corrosion, I suspect that these are originals that were rebuilt and repainted.
                  • Paul C.
                    • November 12, 2007
                    • 511
                    #24
                    The color appears grey not black but with pictures who knows.
                      • 11669
                      #25
                      It's just very flat black sprayed all over everything.
