Didn't realize that my four C3 (1975) seat adjusters are different from each other? The A.I.M. manual shows four different part no's. I just finished re-upholstering my seats and don't have a clue on which adjuster goes where? I know that the right side of each seat has the adjuster arm and the left side of each seat is the "slave" adjuster. The mounting brackets on the slave adjusters are different from each other and the mounting brackets on the adjustment arm adjusters are different from each other. The difference seems to be mainly in the height of the floor mounting brackets. Any help out there?
C3 Seat Adjuster Differences
Re: C3 Seat Adjuster Differences
If you lay the seat tracks in position on the carpet before you install them on the seats you will find they only fit one way. I just put new seat covers on a 75 and found the tracks are not like other years.Lyle
- Top
Problem solved, thanks, ALAL
75 Convertible
L48 M20
Bright Green / Saddle- Top
