427 AIR Adjusting Brace - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    Can someone tell me the length of the 427 AIR Pump adjusting brace?
    I know they are different from the 327 brace. I am looking to buy an original one and I found one but cannot tell if it is correct it is ~11" tip to tip.
    Thank You
    • 43248
    Re: 427 AIR Adjusting Brace
    Thank You
    Tim------
    Attached are photos of an original GM #3921903. It has a developed length of right at 10-1/2".
    • Tim S.
      • March 1, 1989
      • 124
      Joe thanks for the pic. I am not sure of developed length but I assume that is end to end on a plane. It is hard to tell as all I have is a pic
      of the one for sale but and they look the same so how long is the small block adjusting brace and are they the same shape?
        • 43248
        Tim--------
        Developed length is the length of the part if it was flattened and straightened. It can be measured using a string or tape.
        The small block brace has less of a total off-set than the big block. However, it's GENERALLY the same contour as the big block with two offsets. While I have several of these, I can't get at them right now to measure. My vague recollection is that it's a bit longer than the big block.
        The small block brace is MUCH easier to find than the big block.
        • Tim S.
          • March 1, 1989
          • 124
          Tim--------
          Joe that is OK, Paragon sells the BB one for $45, apparently they are slightly shorter with a different bend as you indicate.
          Not worth taking a chance on an original since they have no ID markings as I underdtand it.
          Thanks for your help
