1994 corvette coupe gauge cluster - NCRS Discussion Boards
  • Eddie R.
    • February 27, 2012
    • 22
    Hi. I am replacing the entire gauge cluster in a 1994 corvette coupe. Is there anything I need to do other than just install it again. (i.e. reprogram the computer or anything else?) How do I change the mileage on the new cluster to match the mileage on the old cluster? Thanks for all your help. You guys are all great. Eddie Robin
    • 43219
    Re: 1994 corvette coupe gauge cluster
    Eddie------
    The mileage is retained within the body computer, not the instrument panel, itself.
    If you're doing something as involved as replacing the instrument panel in a 1994 Corvette, I hope you have the factory service manual and have studied the procedure before attempting the repair. It should answer all your questions and pretty much lead you through the operation.
    • Ed N.
      • May 16, 2010
      • 997
      Eddie, you may want to reach out to Paul Schwack, he's been down this road already and knows the process quite well.
      Ed Nieves
      NCRS #51799
      • Eddie R.
        • February 27, 2012
        • 22
        Thanks for the advice Ed. How do I get in touch with Paul Schwack? Thanks Eddie Robin
        • Mark H.
          • September 18, 2013
          • 241
          Up at the top of the page is "community" there's a drop down "Member list". He should be in there and you could send him a PM.
          • Douglas L.
            • May 8, 2015
            • 181
            I believe in 1994 its a simple remove and install procedure, no programming involved. I do believe you will need to drop the steering column a bit for access though.
            Good Luck, Doug
