63 ball joint torque? - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    I can't read my AIM, can someone please look up the torque specs for upper and lower ball joints for 63?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • 6950
    Re: 63 ball joint torque?
    Mike, the lower is 90 ft. lbs. upper is 50 ft.lbs and the align cotter pin after torque.
    • Michael G.
      • November 12, 2008
      • 2157
      Thanks Ed, I am not prepared today, my service manual is 250 miles away. How about the flywheel to engine and clutch attaching bolts?
      Mike
        • 43247
        Mike-----
        Clutch cover bolts------35 lb/ft
        Flywheel bolts-------60 lb/ft
        Keep in mind that both of these bolts are special bolts. I recommend ARP products for both. The ARP bolts may have different torque specs from GM. If so, it will be included with the bolt package.
        • Michael G.
          • November 12, 2008
          • 2157
          Thanks Joe
          Mike
            Thanks Joe
            Mike -
            Also note that the ARP flywheel bolts are slightly longer than the GM bolts, and the bolt tips MAY interfere with the stamped sheet metal clutch inspection cover, causing a racket at first-start like being in a tin outhouse in a hailstorm. It's harmless, and a minor rework to the cover will eliminate it.
