4 wheel alignment service - NCRS Discussion Boards
  • Garlan G.
    • March 1, 1996
    • 1
    I have completed a body off restoration on a 1967 coupe. Searching for a reputable 4 wheel alignment service in the Peoria, Il area.
    • 43247
    Re: 4 wheel alignment service
    Garlan------
    There are probably lots of reputable and competent 4 wheel alignment shops in Peoria since the vast majority of modern day cars require 4 wheel alignment. However, you need more than just a reputable and competent 4 wheel alignment shop. You need one that's reputable and competent with 63-82 Corvette 4 wheel alignment. That's a MUCH smaller subset of the aforementioned. Before you take it to any shop you want to make sure they are EXPERIENCED with Corvette 4 wheel alignment and, particularly, rear wheel alignment.
      • 6950
      Garlan, Make sure to bring the correct alignment specs. with you just in case they may not have them, Below is similar threads and Duke W. has posted them. on a restored chassis this alignment should be a easy task. another thing to keep in mind is if your doing flight judging you may want to purchase the correct asst.'d shim kits for the front and rear. most places don't have them.
      • David R.
        • April 30, 1991
        • 42
        I would suggest Uftring Chevy in Washington (IL).
        78 white L82 M21
