67' 390hp master cylinder cap plating - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    Is the master cylinder cap suppose to be yellow(or golden hue) cadmium dichromate or cadmium/zinc? The 67' tech manual and judging guide pg 163 says "The fill cap is stamped steel cadmium dichromate plated with two domes." ???? To me this means it is the std. cadmium dichromate; however, when i see lots of vettes most of them have the yellow/golden hue which technically is the yellow cadmium dichromate. Can someone please clarify this for me.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 67' 390hp master cylinder cap plating
    Dave,
    Master cylinder cap is plated yellow zinc dichromate. First plated zinc then dip in a secondary dichromate dye.
      • 43289
      Dave------
      One more thing: the plated finish appearance of the original caps differs quite a bit from most reproductions, GM later replacements, and original caps re-plated in modern times.
      The original finish had a deep, rather dark "goldish" color and was absolutely NO GLOSS. There was no trace of "rainbow" hues often seen in these caps nowadays.
      • Enzo C.
        • January 12, 2012
        • 536
        Dave here is a pic of my fill cap as it was intended to be ... Looks like original image.jpg
        Enzo Colosimo
        Ncrs Ontario Chapter Chairman 🇨🇦
        ENZ-Z06/67
        • Steve B.
          • March 1, 2002
          • 1192
          Enzo, who plated your cap?
          • Enzo C.
            • January 12, 2012
            • 536
            Steve I got it from Ara the god father of Corvette parts... Maybe he will see this request ?
            Enzo Colosimo
            ENZ-Z06/67
