Broaching - NCRS Discussion Boards
Broaching
  • Morris R.
    • May 7, 2012
    • 213
    Broaching
    Saw a 327/350 block this weekend without any broach marks from what I saw, is it possible that a block could leave the factory without any and if so, why would/could that happen ? I ask the ower if he knew, he said that's the way he bought it 15 years ago. Looking for some opinions.
    Thank you
    • 43272
    Re: Broaching
    Thank you
    Morris-------
    It could not happen. The surface of the block had to be machined (broached) and I know of no way to do that without leaving any broach marks, whatsoever. They might be subtle, but they have to be there.
    • Frank D.
      • December 27, 2007
      • 2703
      Re: Broaching
      Engine was probably decked at some point in its past...
      • Joe R.
        • July 31, 1976
        • 4552
        Re: Broaching
        Morris,
        Yes, a block could be smooth and I have seen several. Due to rusting the broach marks can disappear as they are not very deep into the surface of the block.
        But as Joe L. says they were there when the block left the factory.
        You didn't mention but was there any stamped marks on the block? A factory replacement block should have had the letters CE.
        JR
        • Ray G.
          • May 31, 1986
          • 1189
          Re: Broaching
          Hello;
          Al Grennings books and seminars are worth the time and $s.
          Ray
          I hope you dance
            • 43272
            Re: Broaching
            Frank-------
            Even if it were decked, there would still be broach marks. They would be circular, but there nevertheless.
            • Morris R.
              • May 7, 2012
              • 213
              Re: Broaching
              Thank you everyone question answered!
              • Bruce M.
                Infrequent User
                • January 9, 2014
                • 27
                Re: Broaching
                You may have encountered a case similar to my 66 L36. It has vertical broach marks rather than the normal horizontal ones, and they are very faint, yet the pad is perfectly clean. Al Grenning judged it to be original at BG, so there must be some exceptions out there.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Re: Broaching
                  'Broach' marks are only produced by a 'broaching machine' and not by any other tool- including rotary mills or grinders as used in engine overhaul shops.
                  The appearance of the marks varies tremendously, usually as a result of tool wear. One block might look almost mirror smooth while another might stop just short of appearing like the Grand Canyon. To think that there is one and only one type of broach mark is incorrect.
                  If a pad surface was almost mirror smooth 40-50-60 years ago, there's a good chance that any residual machining marks are even less visible now.
                  • David H.
                    • June 30, 2001
                    • 1559
                    Re: Broaching
                    Originally posted by Ray Geiger (9992)
                    Hello;
                    Ray
                    +1 If you have the opportunity, attend.
                    • Larry E.
                      • 1695
                      Re: Broaching
                      FWIW: Having taken many seminairs with Al Grenning he indicated that it is not unusual to find a original pad w/o broach marks. This is
                      due to age/moisture and etc.. Of course it had them when new. Larry
                      Larry
                      LT1 in a 1LE -- One of 134
                        • 6955
                        Re: Broaching
                        I have a 72 small block that has a pad with little or no broaching and the pad is not a weathered pad, so as Mike W. says tooling bits have something to do with the broach marks.I have to agree with this as I have seen many stamps here on the TDB and while judging (In my short time).
                        • Roy S.
                          Past National Judging Chairman
                          • July 31, 1979
                          • 1027
                          Re: Broaching
                          In fact Larry the following comment will cause some stir but it is very true. Absence of Broach marks has never bothered me, what I don't like is the presence of other machine marks. It is safe to say that old cars age, block surfaces age and if the broach marks were barely visible when new the chances of them being visible now are very slim. However the presence of new created surface finishes of any type, or even rust pits in a area that is typically oily/greasy/dirty should raise a flag.
                          • Gary B.
                            • February 1, 1997
                            • 7064
                            Re: Broaching
                            Roy,
                            Well said. And much appreciated if it encourages others to think the same way.
                            Gary
