C2 Brake Burnish - NCRS Discussion Boards
C2 Brake Burnish
  • Richard E.
    • 252
    C2 Brake Burnish
    What is good reliable method to "break-in" new brake pads? Rotors are stock (original) GM and new pads are current GM replacement type (17D8) for C2 Corvettes. Is burnishing necessary?
    Thanks for the help.
    • 6958
    Re: C2 Brake Burnish
    Rich, I think the best break in is slow easy stops for the first 50 miles and avoid hard stops, brakes really do not needed a break in period with the finish on brake rotors today, but this is the way I do it to bed the new pads into rotors.
    • Michael J.
      • January 27, 2009
      • 7173
      • Gene M.
        • April 1, 1985
        • 4233
        Should take the glaze of the rotor.
        • Donald O.
          • May 31, 1990
          • 1593
          Another vote for these procedures
          I use course scotchbrite pads on a small buffer. Takes off the glaze and keeps it smooth.
          Don
            • 15706
            New pads with new or freshly turned rotors will break-in very quickly. Used rotors require more consideration - as much as two to three hundred miles of light to moderate braking, which is typical of normal driving. As the pads bed-in, pedal effort for a given deceleration should decrease slightly, and this is the indication that the new pads have bedded-in with the rotors/drums.
            • Richard E.
              • 252
              Thanks everyone for your help. I heard of burnishing procedures like Mr. Johnson mentions in this thread. This seemed awful harsh for a C2 Vette so I thought I better ask. My rotors are "used" factory rotors (but in good condition). I prepared the rotors using 3M brake rotor surfacing discs (p/n 01410) to clean off the glaze.
              Thanks again.
