C2 Side exhaust covers - NCRS Discussion Boards
  • William G.
    • April 1, 1978
    • 154
    What color should they be on the back side
    I have a set of NOS GM side exhaust covers with one light gray and one darker gray on back side
    Were originals all one color or were they different , if different did the heat from exhaust change
    the color to make them the same
    Are the inside of the side pipes judged
    . Thanks Bill
  • Mark D.
    1984-96 Team Leader
    • June 30, 1988
    • 2162
    Re: C2 Side exhaust covers
    Light gray is later service replacement.
    Kramden
    • William G.
      • April 1, 1978
      • 154
      Are the inside of. Side exhaust covers judged
        William -
        Yes, to check for presence of the insulators.
        • William G.
          • April 1, 1978
          • 154
          John
          thanks for your reply
          one question: do they judge the color
          bill
          • Ara G.
            • January 31, 2008
            • 1108
            John
            bill
            Yes...they are....
            • William G.
              • April 1, 1978
              • 154
              I purchased these in 1978 (pair) one is light gray and one is a darker gray on the insulator
              will they both pass judging if on the car at the same time
              • William G.
                • April 1, 1978
                • 154
                Can one of the c2 judges answer the guestion above
                • Gary S.
                  Super Moderator
                  • February 1, 1984
                  • 460
                  I have owned many sidepipe cars over the last 30 years. Plus, I have judged a number of times in that section for what it is worth. The judging guide says they are dark gray when viewed from the front side..no mention of the inner side of the insulator. Probably most judges would deduct for one side of your two colors as a minimum which won't be a life and death deduction or worth the money to change it. At issue with me is all the assembly line insulators I have ever seen (65, 66, 67) are black front and back...or the darkest gray you would ever see. Pictures below for your humor. It surely seems if a car does not have black (dark gray) on the inner side, it should get a deduct of some sort too, but then again an owner can argue the judging guide does not state anything about that. That is just another of the many things not clear in judging manuals. As stated above by a poster, lighter gray is a service replacement insulator.
                  As for judging manuals, I wish they were written more as an outline and less as a narrative. That would allow for more information like this to be printed. And, it would make it much easier for judges who get "stuck" judging unfamiliar years as happens many times at chapter meets.
                  Other opinions?
                  L-R: 1. Cover from first known 65 sidepipe car, 2. my used covers, 3. orig insulator separated, 4. after-market light gray, 5. cover from wrecked car
                  6. And the last one is 65#21326 which is a 5 star car now. I took this picture when evaluating the car for purchase and the pipes and covers were factory original. All the body panels were that expected light gray color, but the pipe insulators were black fiberglass.
                  Insulator.jpgSidePipeCoversAll.jpgSidePipeInsulatorLoose.JPGSideCoverInsides.JPGSidepipes.jpgSidePipeInsulator.JPG
                  Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
                  • Dan L.
                    • May 9, 2012
                    • 97
                    I need to replace a missing exhaust side pipe front insulation piece - how does it attach to the inside of the exhaust cover? Thanks
                    Dan 54915
