OEM Rear Quarter Panel Trim Pieces for 1971 Convertible - NCRS Discussion Boards
  • Mark C.
    Infrequent User
    • July 24, 2011
    • 2
    Trying to find a set of OEM rear quarter panel trim pieces with shoulder harness cut outs for a 1971 convertible. I'm just interested in GM part numbers 3974051 and 3074052. Color isn't an issue, but I need them to be in good shape (no cracks, missing attachment points, etc.) Any suggestions? I've tried eBay and all the OEM part suppliers I know without luck. Any suggestions? Thanks!
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: OEM Rear Quarter Panel Trim Pieces for 1971 Convertible
    Mark,
    Not sure if these are what you need, but I found these at Yogi Bairs Vette Parts in Linesville, Pa. Rather pricey, but you said you wanted original.
    They didn't list GM#, that I could see. If parts are correct, give them a call, may be you can negotiate. 1-808-421-9644 . You could also check with Big City Corvettes out in California. I've used them for many original parts. If you don't see what you want on their on -line store, shoot them an email letting them know what your looking for and they will check their inventory for it. Shipping costs are very reasonable and most times included.
    Hope this helps.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • Bill L.
      • January 31, 2004
      • 1403
      Keep in mind they are the same through early 74 if memory serves me. I eventually found a set on ebay that had minor cracks and all of the threaded inserts were stripped. The repairs were not that tough just time consuming and undetectable once installed. A lot depends on where they are cracked.
      As you have found, originals are becoming scarce.
      Bil
      • Mark C.
        Infrequent User
        • July 24, 2011
        • 2
        Bil
        Thanks - I'll take a look. Appreciate the info. The only original one I've found had a large crack in the upper portion.
