70-72 Rear Compartment Surround Fasteners - NCRS Discussion Boards
  • Michael C.
    Infrequent User
    • August 31, 1990
    • 29
    Greetings!
    I was trying to figure out the correct screws (8) to hold down the storage compartment lid frame to the body. These are the phillips head screws which thread into the j-nuts at the sides and fronts of the pass. side and battery compartments.
    The AIM calls these screws P/N 3843505. I noticed this same part number for the (4) screws which hold down the shifter plate to the console. The screws in the shifter plate are black oval head (#6 size head on a #8 screw) but the JG says the rear compartment frame screws should be chrome FLATHEAD.
    What is going on here, and what would be the correct style screws for the rear compartment frame? My car has some chrome on the battery compartment end, and some black on the Pass. Side.
    Thanks for any help!
    Mike
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 70-72 Rear Compartment Surround Fasteners
    Screws for sides and front are the dark Philips flat head ones.. The rear frame to body are the chrome screws with large chrome special flat washer.
    • Reba W.
      • 938
      On the corners of the console top, we have found original 1970-72 cars with either black oval-head or flat-head Philips screws, and even a mixture on the same car.
        • 3422
        Hi,
        I've been amazed at the variety of fasteners used to accomplish these doors!
        These are from my mid- January 71.
        • Michael C.
          Infrequent User
          • August 31, 1990
          • 29
          Thanks Lady and Gentlemen,
          I appreciate your input. Alan, the picture helps a lot. I have the same fasteners concerning both washer-head screws and the short machine screw. RE: The remaining two flathead screws (one chrome 3/4" and one black 5/8") where were these located on your surround frame?
          Mike
            • 3422
            • Mark E.
              • April 1, 1993
              • 4609
              Here are the fasteners across the rear of the frame. You can use make out the rivets in the picture. AIM Item#3 PN3828548
              Are those really the proper screws shown holding the compartment frame to the floor? The washers are so large they interfere with the frame and they don't look like they are seating very well.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
                • 3422
                Hi Mark,
                Yes, they're actually typical of production!
                Remember, there's a long thin steel reinforcement on the other side of the underbody that these screws mount in.
                I think the large washer is there to spread the load generated by the doors opening and closing across the surface of the plastic frame.
                • Mark E.
                  • April 1, 1993
                  • 4609
                  Hi Mark,
                  Thanks Alan, that's good to know as I reassemble my compartment. It seems like the fasteners would fit and look better if the screws going into the door are swapped with those going into the frame and body. But I've learned that what looks right on these cars isn't necessarily TFP.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Bill L.
                    • February 1, 2004
                    • 1403
                    Oh geeze Alan. Now I see my center console plate screws are wrong. The search for correct screws begins.
                    Bill
                      • 3422
                      • Rich C.
                        • January 1, 1994
                        • 383
                        Alan,
                        As always your detail photos are OUTSTANDING!! If you ever decide to publish a book featuring all the photos I imagine you have, I'd buy it immediately. Again thanks for your input!!!
                        1973 LS-4 454 coupe owned 25 years
                        1996 LT-4 CE coupe
                        Sierra Nevada Celebration Ale-currently on tap!
                          • 3422
