63 seat belt - NCRS Discussion Boards
63 seat belt
  • Christina O.
    • July 13, 2015
    • 18
    63 seat belt
    I am a short and have the seat all the way up and found the seat belt is not long enough to clasp. I worry that if I get pulled over that I could be ticketed for not wearing it. Any suggestions? I understand that the belts were a dealer installed item- is that correct?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 63 seat belt
    Nooooooooooo. (had to extend message to qualify as a message.)
    • Mike E.
      • February 28, 1975
      • 5139
      Re: 63 seat belt
      Seat belts were factory installed in all Corvettes from 1958 on. You might look around for a seat belt extender like the airlines use. They should enable you to use the belts.
      • John D.
        • December 1, 1979
        • 5507
        Re: 63 seat belt
        Christina, At Corvette Carlisle there's a vendor next to me on "L" row. Snappin Turtle from PA. 800-843-3696
        They sale various colors of seat belts. 63's look a likes (no good for judging) but very presentable. The buckle is similiar as I have been staring at them for many years and thought that. I understand their belts are longer than 63 originals. But confirm that with them.
        The belts are very inexpensive/affordable.
        Plan B. Have Seat Belt City Charle make you up a minty set of belts that are longer that will pass judging. If the judge doesn't measure them.
        Don't have his address but others here do. John D.
        • Christina O.
          • July 13, 2015
          • 18
          Re: 63 seat belt
          Thank you for the information on when the were installed. I will look for an airline extender.
          • Daniel D.
            • December 9, 2009
            • 105
            Re: 63 seat belt
            When I purchased my 65, the belts were missing. As a temporary measure I purchased a very inexpensive set ($18?) from retrobeltusa http://www.retrobeltusa.com/ They sell different lengths and colors. I selected a blue that looked decent in my bright blue interior. It looks like they also sell extenders. I'm not 63 expert, but I think the Chrome Aviation style that they sell would look appropriate in a 63 (but obviously not something that would pass judging). I have since found a set of originals that I had redone by Charlie at Seat Belt City.
            • Don H.
              • December 1, 1981
              • 1487
              Re: 63 seat belt
              I doubt the airline seat belt extender will match the original hardware. Don H.
              • Joe R.
                • July 31, 1976
                • 4551
                Re: 63 seat belt
                This lady is trying to get past the police and protect herself from injury. She is not worrying about passing judging. She wants advise how to avoid getting a $250.00 ticket.
                The seat belt extenders would be ideal thus saving her a court appearance and a ticket!
                JR
                PS. Seems as if this lady drives her Corvette on the OUTSIDE of a trailer! Yeah!
                • Chester C.
                  • May 29, 2013
                  • 154
                  Re: 63 seat belt
                  Ky law does not require seat belts in a car that old..Maybe your state is the same.
                  • Christina O.
                    • July 13, 2015
                    • 18
                    Re: 63 seat belt
                    Once we are ready for top flight then I will worry about the judge. But for now that $250 could be used towards gas...cooler days are coming to Florida. I will try retro belt extender and seat belt city, hopefully they can help. This year is will be the first time to the Lakeland show, I am sure I will be over whelmed by vendors.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      Re: 63 seat belt
                      You can get seat belts that are longer for temporary use very cheaply - do a web search.
                      I know plenty of restomods running them...takes all of about 20 minutes to install them.
                      • Bob R.
                        • June 30, 2002
                        • 1595
                        Re: 63 seat belt
                        It only takes twenty minutes to install them if the old bolt comes out. I had an awful time removing one of the bolts in my 63 and ended up very carefully using a small torch. If the seat bolts are original and the car is 50+ years old the may not come out easily.
                        • Stuart F.
                          • August 31, 1996
                          • 4676
                          Re: 63 seat belt
                          The repro/aftermarket set I use in mine had mounting plates that were barely rounded instead of triangular tapered and would not fit into the corner between the floor and rear vertical panel. I had to grind them into shape to fit. Some day I'll shell out the dough to have my originals re-webbed. My buckles and mounting plates are in good shape, but the webbing is frayed from my sandpaper pants, I guess.
                          Stu Fox
