58 weather strip t nut position - NCRS Discussion Boards
  • Fred J.
    Infrequent User
    • October 24, 2015
    • 3
    I see the assembly manual shows the t nut down through the hole in the side window frame and the screw up through the metal strip and rubber. Though the video is poor, al knock seems to put the t nut over the hole and the screw up through from below. Makes sense to me to be down through but it does limit how tight it is screwed down.
  • Mark E.
    • April 1, 1993
    • 4607
    Re: 58 weather strip t nut position
    Do you have a question?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Fred J.
      Infrequent User
      • October 24, 2015
      • 3
      Which way is the correct way?
      • Thomas H.
        • August 31, 2005
        • 1068
        Flat part of the t-nut against the frame. Threaded portion up in the air.
        Tom
        2007 Z06, Lemans Blue
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11363
          Some clarification....
          1956 to 1958 side weatherstrips originally had integrated studs within integrated reinforcements embedded in the rubber. The front sides and header w/strip was a one piece assembly. The 6 side w/strips were wrapped with a canvas cloth originally.
          topws027.jpg 59topframe001.jpg59topframe002.jpgcloth_covered_ws2.jpgcloth_covered_ws4.jpgcloth_covered_ws5.jpg
          Part #'s on the backsides below the cloth covering.
          Not available in reproduction now, so all rubber replacement are now the later type using the separate rubber and metals, T-nuts and screws.
          I believe at some time in 1959, likely early, the parts changed to separate rubber piece and separate metal reinforcement which then used the T-nut and screw arrangement. This continued through the 1962 Model Year. These are original metal reinforcements, which are much thinner than reproductions available today. Pictured after cleaning and before semi-flat black paint.
          The 1959 AIM shows the barrel of the T-nut through the frame, then the Phillips head screw into the metal reinforcement then through the rubber into the T-nut to secure it. Not very good photos but shows the method. Original T-nuts shown also. The barrel end of the T-nut will sometimes bottom on the metal but by design it will stay secured. I also recall original T-nut barrels are a tad shorter than the reproductions which may account for more frequent bottoming out when using them.
          • Thomas H.
            • August 31, 2005
            • 1068
            Tom
            Disregard the bum info I replied with. Rich is correct - barrel through the frame. Makes more sense.......... I got my info by looking at the frame of a car in a resto shop - questioned it, was told that was the right way! Hmmm.....
            I used the cloth covered ones on my 58. Studs with nuts.
            Tom
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11363
              Tom
              Tom, Did you recover the cloth yourself with the Bowdrill tape? Any photos? How did you handle the transistion at the forward corners into the header w/strip?
              Rich
              • Fred J.
                Infrequent User
                • October 24, 2015
                • 3
                I want to thank everyone for the responses and Richard the documents, pictures and explanation has proved very helpful. In fact they have answered some questions I had not yet thought of.
                Fred
                • Thomas H.
                  • August 31, 2005
                  • 1068
                  Rich
                  Rich,
                  Mine were new Al Knoch parts. I thought they fit pretty well.
                  Tom
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11363
                    Tom,
                    I didn't know AK had them available. Thanks.
                    Fred, et al......
                    BTW, For the record, 6 or 7 years ago when I discovered I had my original type w/strips in a box from removal 20 years earlier, I posted a thread here with questions.
                    https://www.forums.ncrs.org/showthre...p+weatherstrip
                    Roy Braatz and I had many phone conversations and he graciously shared his knowledge with me about the differences and nuances of these soft tops, frames, and weatherstrips. He saw my enthusiasm and interest and was happy to help me.
                    Roy was a huge help to my learning process and I have collected much information over the years while restoring and installing on my own cars and helping to share this with others. I need to give Roy credit for mostly all of my knowledge. Thanks Roy, I know you're out there.
                    Rich
